Solarforce L2T Drop-in
AIC
I'm looking to buy the Solarforce L2T, but I'm having trouble finding a drop-in that fits my needs.
What I want is a 2 or 3 mode XP-G or lower powered XM-L (less than 500 lumens max).
Those seem easy to find, but the hard to find features are the mode sequence of Low-High, or Low-Med-High, and NO memory.
I would mostly run this on 2 cr123a, maybe a little on 18650 as well.
A push in the right direction, or a recommendation towards a custom maker that might suit my needs would be great.
I've been looking for a similar dropin but no one makes one without memory and current regulated. All the Nailbender and Vinh dropins are PWM and have memory. The only one I've found that is close is the EDC+ X60L dropin with current regulation and no memory. The only issue is they turn on in High mode and click down. I inquired about having one that starts in Low and goes up, but Jason from EDC+ says there are no plans for such a UI unless there is more demand for it. That's why I ended up ordering the Lumintop ED20 instead. It's the only light I've found that seems to fit my needs, but it uses PWM for the Low mode and current regulated for Med and High. I'm just hoping the 800Hz frequency is high enough to not bother me...we'll see.
