I recently purchased an Aurora WF-600 HA-III SKU.8537 from DX as a budget thrower, i wasnt expecting much for $39.22 but it was suprisingly good. This was my first LED thrower so full of enthusiasm and after reading a heap of reviews and threads i ordered a Solarforce Masterpiece Pro-1 with L2X HA3 body ( 2 x 18650's).
I went out to a local quarry tonight to compare the 2 flashlights and the results were totally unexpected. The Solarforce which cost $90.98 (more than double the DX light) was only at best 15% brighter (subjectivly at least) and didn't seem to have much more throw. Given that the Solarforce has a larger deeper head and runs off 2 x 18650 instead of 1 like the Aurora i was expecting it to completely blow the Aurora away.
So after 1 day of ownership im ready to put the Solarforce for sale and stick with the Aurora. Am i being too hard on the solarforce? Are my expectations too high? I realise that above a certain point you get diminishing returns (like with most things) but i just cant justify the cost of the solarforce for its minimal imrovements over the cheaper torch. I thought its worth pointing out that i was using the same batteries in both torches and the hot spot was similar for both, but the Solarforce had a little more useable light around the hot spot.
Does anyone have some suggestion's to explain the disappointing performance of the Solarforce?? and would you care to make a recommendation on a better thrower to try? Ideally i would like a slightly larger hot spot but at the very least more throw. My budget is max $125 and please dont suggest HID, interested in LED only thanks :)
