Sold/Expired ***SOLD***Manker E14 III 4000 Lm Mini EDC LED with USB Type-C Rechargeable Battery
ipaulr
Boulder, CO
Manker E14 III 4000 Lumens Mini EDC Pocket LED Flashlight with USB Type-C Rechargeable 18350 10A Battery
This is a brand new flashlight, just received. I opened it and tested it, and now you can have it at an excellent price. (It's a really nice light, but I have too many like it.). This is the Cool White version.
Price: $50 shipped to CONUS
Manker EC14 III 1.jpgManker EC14 III 2.jpgManker EC14 III 07.jpgThe Manker E14 III flashlight features a unique hybrid design of both copper and aircraft grade aluminum. The copper part not only looks great, but acts as the heat sink! The emitters are four Samsung LH351D LEDs and can put out an impressive 4000 maximum lumens on turbo.
Specifications:
  • Emitters: 4 x Samsung LH351D (Cool White: 6500K, Neutral White: 4000K CRI>90)
  • Powered by 1 x 3.7V 1100mAh high drain protected 18350 li-ion battery with Type-C USB port (Included)
  • Maximum output: 4,000 lumens
  • Maximum beam intensity: 6,000cd
  • Maximum beam distance: 155meters
  • Working Voltage: 2.8-4.3V
  • Driver: Most efficiency constant current circuit (Non-PWM)
  • With advanced intelligent temperature regulation module, E14 III regulates its output and adapts to the ambient environment, maintaining optimal performance
  • Anti-reverse battery protection & over-discharge protection
  • Pocket Size, Compact, lightweight
  • One-handed, one-button for easy and fast operation
  • Lockout mode prevents accidental activation
  • Moonlight Mode: Multiple user selectable levels
  • Low battery voltage indicated & battery charging indicated
  • Material: aircraft-grade aluminum body with copper heat sink and stainless steel button cap
  • Surface Treatment: Premium type-III hard-anodized anti-abrasive finish
  • Clip: Stainless steel deep carry clip
  • Lens: Toughened ultra-clear glass lens with anti-reflective coating + high temperature resistant Carclo® optics TIR lens
  • Install one removable silica gel light filter plastic sheet (green glow gadget)
  • Tail-stand compatible
  • IPX-8 waterproof standard (2 meters under water)
  • Impact resistance: 1 meters
  • Size: 71.2mm (2.8") length x 28mm (1.1") head dia. x 25.8mm (1.01") body dia.
  • Weight: 82.8g (2.92oz) without battery, 109g (3.84oz) with battery
What's Included:
  • 18350 Battery, USB Type-C cable, Spare O-ring, Lanyard, and User Guide
Modes & Runtimes:
  • Moonlight: 0.5 lumens, 82 hours
  • Low: 180 lumens, 4 hours 39 minutes
  • Middle: 400 lumens, 1 hour 34 minutes
  • High: 1000 lumens, 1 hour 15 minutes
  • Turbo: 4000 lumens, 55 minutes
  • Strobe: 4000 lumens, N/A
Mode Chart:
Operation:
  • From OFF, long press for moonlight mode. Press and hold to cycle through 5 different moonlight levels. Click once to exit and set the brightness into mode memory.
  • From OFF, click once to get into the general modes; Press and hold to cycle through Low > Middle > High. Release and click once to turn off and set that brightness to mode memory.
  • From OFF, double click to jump into turbo the highest lumens. single click to exit.
  • From OFF, click three times to enter special modes. Hold down to select from strobe, beacon, or SOS. Click once to turn off.
  • From OFF, click four times to LOCK-OUT. Click four times again to unlock.
Battery Options:
Battery: This item includes 1 x Manker High-drain 18350 battery with built in USB Type-C charging port.
Re: Manker E14 III 4000 Lm Mini EDC LED Flashlight with USB Type-C Rechargeable Batte
You got a great deal! Just got one and I wanted to ask if you notice if the Manker 18350 battery little green led on top stays on after you remove the charging cable? I had a problem initially with this battery after a full charge (green light) and USB inline meter showed 0.0 current draw I removed it and a voltmeter (Fluke 77) was reading the voltage bouncing between 3.34 and 3.68 volts. Should have been about 4.1 to 4.2 volts if fully charged and should be steady. I even put it on an oscilloscope and the voltage was bouncing with a lot of 'noise' about once per second. It wouldn't even allow the light to turn on but after some fiddling with a couple more charges it started working. However it seems odd the green led on the battery stays on all the time.
Sorry, I don't know anything about that. I have this with all packed up and ready to ship so I really don't want to crack it open and retest it. The one I did tested it seem to work fine
Are you shipping it back because of a problem? Thanks for the quick reply. I simply was interested in whether that little green light stays on after unplugging it for the most part. No real problem though....
No, not shipping it back to manker. There's nothing wrong with it, it's fine. I don't think it's fair to order an item to try it out and then send it back. So I'll just sell it myself. It's a fine light.
By the way, it doesn't seem odd to me that that green light would stay on for a while after the charging. After all, the battery can easily power that little green light for a very long time.
