Sold/Expired Sold: Ra Clicky Tactical
aikiman44
New York
Received today and it's a fantastic light, but I have a chance at the 170 lumen version.
3 levels, 140 lumens, programmable, ano'd black, clip w/ instructions and card included. Battery also included
Sold.
From Henry's site:
The Ra Clicky Tactical flashlight provides the following features:
140 lumens maximum output. Tighter beam pattern reaches 20% further than normal beam pattern.
4 preset brightness settings - 140 lumen tactical strobe, 140, 12 and 0.3 lumens. The brightness settings and the turn-on setting may be customized for special missions.
Elegant single button interface includes momentary button operation.
Constant brightness through constant power regulation.
Gracefully low battery warning.
Designed for both regular lithium batteries and rechargeable Li-ion batteries. Protects rechargeable batteries from over-discharge.
Full thermal management.
Potted electronics for the ultimate in reliability under extreme conditions.
Anti-damage battery compartment protects battery under extreme conditions.
Nearly unbreakable ultra clear glass lens with anti-reflective coatings.
Aerospace aluminum protected with black military Type III hard anodize. Stainless steel crenelated bezel blackened with AlTiN.
Raised button.
Customizations include turn-on setting, momentary operation, automatic shut-off, button lock, locator flash. Output settings can include burst output, tactical strobe, emergency strobe signaling and emergency SOS signaling or any brightness level.
Reverse battery protection without diode power penalty.
Pocket clip, deep carry bezel up, MOLLE compatible, retaining.
Water resistance: 2 atmospheres (20m or 66 feet of water) - static.
Dimensions: Ø 25.4mm x 98mm (Ø 1" x 3.85").
Weight: 100g (3.5oz) including battery.
