Hellbore
OK I am having a strange problem.
I have an Elly modded to run a Cree p4 LED direct-drive off an unprotected 14500 lithium ion cell. Inside the head, where the driver circuitry used to be, I installed a lithium ion battery protection circuit, so it can safely run unprotected cells.
The point where the positive battery terminal contacts the driver board is coated with solder. I don't remember if I did that or if it came that way. Anyway, a while back I put a solder blob on the positive terminal of one of my 14500 batteries to make the cell fit better in one of my flashlights, because the unprotected cells are a bit shorter than AA batteries.
So now, if I put this cell into this light, the positive battery contact is solder against solder. It is silver solder.
Anyway, here's the point of this long story. With this light, if I shake it around or pump it, the light flickers. Afer while it will start to flicker when I first turn it on. It looks like a flicker due to contact issues... and it is. If I remove the battery, the positive terminal of the battery (where the solder is) is all gray and.. oxidized? burt? Not sure what to call it. There is also a smell that reminds me of the smell when I'm soldering.
So, it appears that solder is a poor choice for battery contacts... it looks like when the light is bumped there is some arcing that is causing the solder to oxidize or something, I don't know what. Over time it gets worse and the battery terminal gets more and more burnt and has more and more contact issues and causes more flickering.
Can anyone explain why this happens? I guess I need to carefully remove the solder from the battery terminal, and possibly throw the cell away.
