Ok guys, I have been hanging around pestering you for a while now, I have finally got the inspiration to do a project but I am still an electrical retard, I can solder and put things together but am no good with the theoretical stuff so I need your help please.
I want to create an umbilical torch, I have the donor head,
http://www.ebay.com/itm/80M-Underwa...8840011?pt=US_Flashlights&hash=item20cf6adacb
I have a battery pack and cable, but what do I do now?
My donor head has 1 xml-t6 led which runs off of a 26650 battery, as i understand it xml's can only run @ around 3.5 - 4 volts, the battery pack that I intend to use is a 12v 4500mah pack, so can I use a driver to reduce my 12v to 4 volts? I have this driver laying around
http://www.ebay.com/itm/360472948472?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
can I just wire this between the battery pack and the existing circuit? Or would I be better off creating a new battery pack of some 26650 batteries in parallel?
If I go with the 26650 batteries how do I charge them?
