Al_Havemann
Got my XM2 2 days ago and thought I’d post a few comments.
First, the light lives up to it’s promise in regards to the beam quality. It’s nearly flawless, tight, great throw, very white and very powerful. It’s a bit brighter than my L4 and also a bit more white. Run time is quite good, but it does drop some in output as the batteries discharge and then goes flat in a matter of minutes when the liths fall off the edge. Mechanically, it’s not bad and I don’t have a problem with the tail switch like some have. I applied some damping grease to the tailcap threads to improve fit and feel, it’s much better now.
By far, for me anyway, the biggest problem is the size of the light. By comparison, my L4, which I consider large for an EDC, is svelte and trim. I can EDC the L4 in either 1 or 2 battery configuration without much of a problem but the XM2 is strictly limited to a briefcase or belt holster. It’s chunky and oversize in my opinion but that doesn’t detract from the power and beam quality. It’s probably too powerful for an EDC anyway, more of an outdoor light where that output and throw can be put to an advantage. Poking around a PC isn’t it’s forte.
It’s interesting that a $15 incandescent I bought on ebay is nearly identical in appearance and identical in construction to the XM2. Threads match and parts are interchangeable where there isn’t a mechanical conflict due to one having a bulb and the other a LED. Both have the look and feel of parts churned out by a CNC machine.
The module and optic are easily removable so the obvious next step will be to look for a high quality, smaller host. It’ll pretty much sit around until that happens.
Since I got mine for the early price of $40.00, it’s worth it just for the module and optic.
If I don’t sound all that pleased with it, your probably reading this wrong. I do like it, but I can’t wear a holster with a suit and the XM2 is way too big for a pocket light. If I can’t slip a light into a side pocket, it doesn’t get carried, so for me it probably won’t work unless I can find a new, much smaller host.
Any one have any ideas?.
Al
Al
