Re: Someone please post a pic of..................
I don't have a picture for you, but I can tell you how to select a resistor. That particular IC uses a feedback voltage of 50mV. Thus the current across the resistor must develop 50mv to regulate. V(Voltage) = I (Current) * R (Resistance).
So You know that V = 0.050 volts.
Thus, if you want the stock current of 333 mA, you would divide 0.050 volts by 0.333 amps, which equals ~ 0.15 ohms.
So from that direction, you can find the resistor from the desired current.
The other direction would allow you to find the current from a standard resistor. This would be dividing the 0.050 volts by the known resistor. So if we have a 0.15 ohm resistor this would be 0.050 volts divided by 0.15 ohms, which equals 0.333 amps.
Did this make any sense????
