Hey folks,
I'm new to this market and this seemed like a great place to start. I'm looking for a light to survey/scan habitats like fields, wetlands, even forested areas for birds and wildlife. I'm looking for something rechargeable that will get the job done at a good price. Thanks in advance for your help, it is much appreciated! Let me know if I need to clarify anything.
Thanks!
____I would like to purchase the light from a brick and mortar store. I am located in ___SW Ohio____.
____I will be mail-ordering or buying online, so this doesn't matter.
Either. Gander Mt, Walmart, Target, Meijer in the area, or online.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
Grad student budget, and my first purchase in this market. I'd really prefer value, and would like to keep it under/close to 50 if possible.
3) Format:
____I want a portable spotlight.
4) Flashlight-specific format/size:
____I don’t care.
____I don’t know.
____N/A
Flexible. I'd be willing to carry while hiking or throw in a pack if necessary for longer hikes.
5) Emitter/Light source:
____I don't know.
I'm a novice, you tell me what's best haha. I'm not looking to use for photography, so truest color isn't a huge concern, but enough to be able to see what I'm looking at.
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
Probably best to "keep it simple".
7) What battery type do you want to use?
Again, novice. I'd prefer something rechargable, and the longer lasting, the better.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
I'm using this light to look for/survey birds and wildlife. Basically, scanning marshes/wetlands, fields, treetops.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
I'd be good to it, but it will be out in the field.
12) Switch Type and location (choose all that apply):
____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
Multiple levels would be a bonus, but definitely not necessary.
14)Material/Finish/Coating
____I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
I'm told this is easier on wildlife (especially mammals); this would be a perk (though I don't intend on spotlighting things for minutes at a time, more like 10 seconds, rarely longer, just enough to ID).
**Forgot to mention- In my search, the Stanley SL5W09 looked like it might be what I'm looking for, thoughts on that (will it do the job I need?) or similar?**
Thanks!
____Less than $25.
____Less than $50.
____Less than $100.
3) Format:
____I don’t care.
____I don’t know.
____N/A
____I don't know.
6) Manufacturer:
____I don’t know.
____I don’t care.
