SSC P7
EricR
Hi this is my first post to the forum - sorry if it is redundant.
I'm looking for a refleector for the SSC-P7 led with a max diameter of ~1" and a tight focus of <6 degrees for an underwater light head conversion.
Thank You
You won't find it. It's impossible to focus multi-die emitter so tight with so small reflector/optics.
No one makes such a beast. Perhaps it would be possible with a custom made deep (long) reflector, but don't expect any miracles. It won't be easy to find someone willing to make a one off item like that.
Thank you ! It looks like I need to start over . My goal is a tightly focused LED ~500Lumens to replace a 10W solarc HID.
That's a really tall order, I doubt there will be any truely suitable leds for that task for a year or more. If it were just output it wouldn't be much of an issue, but LEDs are power limited so you can't just drive the small ones hard enough, and larger quad die LEDs with appropriate output are about impossible to focus without a large (2+inch) reflector. One thing you may be able to do that I didn't think of is an aspheric lens. The throw with a simple aspheric lens can be unreal, almost laser like with a single die cree LED. It can be done with a P7 as well but due to the light loss (very hard to get all the light from the P7 directed through an appropriate focal length aspheric) may prove less effective than desired.
Welcome to CPF, EricR.
A similar requirement to yours was discussed in this thread, and Packhorse has done a very interesting modification incorporating an aspheric lens, as described in this thread.
R2's can get near to 500 lumens properly cooled. See this post. With correctly designed heatsinking and using the water cooling, I reckon it's doable. However, you will lose most the efficiency advantages of LED's running it that hard.
No it cannot. XR-E has its limit @ about 2,4-2,6A and it's ~450lm. More current than 2,6A won't give higher brightness.
Gah, I missed the word "near" from that post. Must be more tired than I think >.<
Fixed.
