Hello all.
I have been lurking for a while, reading packhorse's threads and many others - to be honest the more I read the less I seem to know.
I am not really 100% on electronics, I can solder (a bit), I've installed MOSFETs and done big power upgrades in airsoft guns.
I have a small hobby lathe so I am capable of building a new light head.
I bought a used Dive Rite MR-11 that had been converted (at the factory I think) into an LED700/LED LUX.
Here is a picture of the light head:
It isn't blowing me away with power, I guess the option is similar power to a handheld with massive runtime or massive power with reduced runtime and this is in the low power-good runtime camp.
Since I am not a technical diver I don't need more than 1.5 to 2 hours of runtime.
The way I see it I have 2 options:
1: Build my own upgrade.
2: Wait for the Sump Donkey III drop-in upgrade to come out ( I have e-mailed Custom Duo and hope to hear about the projected specs soon).
If I build my own then am I right in saying that for a good, tight beam, good throw and serious brightness then the SST-90 with an Ahorton lens is still the best way to go?
I would be driving it at 9A with one of these.
Battery wise, again, confused.
My used torch came with 2 12v 4500mAh batteries (10 x 1.2 volt cells).
The battery compartment is 59.9mm diameter with 133.5mm of usable depth.
That means if I tessellate the cells I can get 5 22.17mm diameter cells or 7 19.9mm diameter cells into it.
That means that is is possible to squeeze 14 18650 cells into this cannister
Plenty of scope there, I could easily supply 7.4 volt at 15.5 amp hours.
So, do what I said above, driver, LED and lens or is there something better out there.
I know Packhorse was trying to find a good aspheric lens in the 35mm range but I can't find one, is there one out there?
SST-90 still the best for this application?
Driver good enough, anything better available?
Anyway, sorry for the extremely wordy first post and thank you for your time.
