kosPap
note to mederators: i am placing it here cos it is more relevant
I was sent an Ultrafire A30B flashlight (Akoray Clone) to troubleshoot.
the owner said that after a while it acts up and dims or gets off when taped/moved.
I tried both protected and unprotected batteries and it does act up, but every time and ONLy when a battery goes low, like 3.8V.
Bang it forward or backwards and it does it. Add a charged battery and you can kick it around.
I have already excludee bad contact causes. Fully dissasembled and retightened everything, added more solder on the switch PCB ring (it had only one on a side), added a contact spring on the driver PCB, and the batteries tested with were of various lengths.
It is definetely an electrical issue, but what?
