Streamlight Haz-Lo mod?
dafeichu
Hamilton, ON, CA
I was given a Streamlight Haz-Lo at work and would like to improve on its performance by adding a driver and a new LED. Right now the light only has one setting and the O/P has a lot of rings. The case is plastic and it uses three AA's so I'm not expecting a huge improvement.
Any ideas on a LED and a driver? I've taken it apart to see what will fit inside and the star board doesn't look like an issue to replace but adding a driver board might be tight.
Keeping in mind that I have never played with the headlamp in question...
Does the headlamp have a Luxeon LED? I'm guess yes, just based on the output. If so, you should be able to double the output by replacing the Luxeon star with a Seoul P4 on a star, and the Seoul should work with the original reflector.
vt, it is a Luxeon. I do have a P4 around so I'll try it out.
LED_astray, a headlamp of this certification is not needed for my job. It was ordered by one of my colleagues and now that I have it another one can't be ordered.
