Dan2503
If I am to drive an LED with a rating of. 3-18v , will I only get maximum lumens and throw by putting 18v into it.
Thanks
Dan
Thanks
Dan
Do two 3.7v make 7.4v or just a bigger capacity 3.7v.
Thanks
Most buck drivers work best with voltage well above the led's vf.
They usually have a sweet spot (voltage) for the best efficiency......The efficiency will greatly vary with the voltage though.
Here's a buck driver that doesn't seem to follow that. Like 45/70 said it depends on the actual driver.It depends on the actual driver, but generally buck drivers are most efficient with a voltage about 0.5 Volts above the Vf of the LED. The more a driver has to "buck" down the voltage, the less efficient they are. That's not to say that adding more cells (more voltage, as well) to power the light won't increase runtime, it certainly will, but it'll actually be slightly less efficient.
Dave
