stupid question
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
alright, I know this is a REALLY stupid question but does the 5W LS burn 5 Watts of input power? If so, does the 5W Luxeon Star ouput as much light as a 5W Halogen? Is there any way to make it project light far enough for use as a bike light for off-road mtn biking?
The 5W LS nominally puts out 120 Lumens of light at 6.8 V an 0.70 A. This equates to 4.76 Watts.
This is 4 times the wattage of a 1 watt LS at 3.4 V and 0.35 A.
Not surprisingly, this 2 * voltage and 2 * amperage spec is because the 5W unit is actually comprised of 4 1W emitters squeezed together in a 2*2 serial / parallel configuration.
The 120 lumens has an efficiency of about 25.2 Lumens per watt.
The brightest Welch Allyn halogen bulbs approximating 5 watts are rated at an effiency of around 20 Lumens per watt. Efficiency can rise to the 27 to 29 Lumen range between 10 watts and 20 watts.
THANKS for the info!
will using optics create a beam that will throw a good distance for biking?
