pedalinbob
I apologize for the question, but I have searched this forum and still feel a bit shaky on what to do. In the past, I have built LEDs which run from transformers, but I only used low-power LEDs and only one at a time.
I am building a display cabinet for my wife. It will have five 1'x2' shelves, and I just ordered 5 SSCs (1 LED/shelf).
I have been tinkering with an SSC, and determined that 100 milliamps per LED should provide plenty of light, so the question becomes: how should I power this?
I have serveral wall-warts, ranging from Nokia cell phone chargers (3.7v with 340 milliamps) to a 12v model (cannot recall the amp rating).
So, I am looking at 0.5 amp of total current at 3.5v. I looked at several power supplies/transformers/adapters and a case of beer (totally kidding!), and am still not sure what would be best to use (it looks like there are a bunch of different types, which is incredibly confusing!). I went here:
http://www.allelectronics.com/make-a-store/category/815/Wall-Transformers/1.html
I thought I should be able to use a 6v 800ma model and resistors, or the 5.5v 300ma regulated model with resistors...and I believe I would have to run the LEDs in parallel.
(the regulated part sounds good, but I'm a bit confused about how it would react to limiting resistors).
I have also read some threads suggesting using higher voltage and running the LEDs in series. Apparently, I would need a 17.5v+ transformer (24v?), and resistor back the current.
I intend to run the lights for just a few hours after sundown each night, so ultimate efficiency isn't a huge concern, but I still like the power-saving feature of LEDs.
Does anyone see a simple solution? I was really hoping for a transformer, wires, LEDs and a switch...;o)
Many thanks,
Bob
Many thanks,
Bob
