Sunwayman T40CS
Bigmac_79
Kansas
Announced in the Marketplace
● CREE XM-L LED, with a lifetime of up to 50,000 hours;
● Tactical Tail cap press button switch, slightly depress the side switch for different output modes and standby mode:
Three modes constant output, hidden strobe, SOS (below is the output and runtime of using two 2600mAh 18650 batteries)
Three constant output modes: 788Lumens (2hrs)- 220Lumens (8hrs)- 20Lumens (60hrs)
Strobe: 788 Lumens
SOS: 788 Lumens
● Constant current circuit, constant output
● Effective range of 500 meters
● Uses two 18650 or four CR123A batteries
● Working voltage: 5.5~16.8V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 225mm (length) x 64mm (head diameter) x 25.4mm (tail diameter)
● Weight: 273g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tactical forward click switch with momentary on
● Accessories: tactical ring, holster, O-ring, rubber cap
The new thing about this light (for Sunwayman at least) seems to be the addition of a button on the side. Their announcement in the marketplace describes the side switch and rear switch as having different functions. Unfortunately, as seems to often be the case with Sunwayman, I can't quite understand what they are trying to say about it. They also mention the ability to use a remote pressure switch with this light.
kinda hard to imagine a 700 lumen light be able to throw 500 meters of light, i own a tk35 820 lumen thrower but at 300 meters, the light is already so faint, you wouldnt notice it much. will have to wait for Marshall's take on this one. :)
Sounds to me like the tailcap switch is purely used to turn the light on and off - be it constant or momentary - and the side switch is used purely to change modes.
Looks good. I like the addition of the side switch. I think in most cases holding the light underhand is more comfortable. I could actually live without the tail switch altogether.
Hard to tell from the photo angles how deep the reflector is.
Interested to see more!
I think the tail cap may override mode settings to max when pushed with the light on. Then I think I also read the light has a memory. ????? I would love it if the tail cap does have a max out put from lower modes when using the tail switch.
Anybody compare this to a Thrunite Catapult V3, EagleTac M3C4 single XML, or Olight M3X yet?
@tre, sorry I don't have those lights but did do a 172m comparo to other XM-L lights as well as a M3LT (400lms version) and a XR-E here.
