ctownstud00
- Joined
- Jun 5, 2011
- Messages
- 11
Hey all, I'm new and I've been doing my best to learn about LEDs; however, I feel like I'm at a point where I need some personalized guidance. I need a great value in price, but I am extremely picky when it comes to quality. I've been leaning towards something like a Klarus XT11, ThruNight TN11, or a Xeno G42 XM-L U2 (kinda hefty, though), but I don't want to spend quite that much, since I have such a limited budget, and after purchase of the light, I would like to purchase a weapon mount and pressure switch (and possibly other extras, like a red or infrared filter).
I gather that driving the LED with an appropriate battery is important for achieving maximum brightness. I'm thinking I want a CREE XML-t6, and hoping to use rechargeable CR123As (because I already have some). Unsure if that will achieve best results or not. I also gather that using the rechargeables will cause more power, hotter temperatures, and less runtime.
Additionally, I think I dislike PWM, if I understand correctly that it adds a visible pulsation to the light!
For all questions please select all that apply.
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $50. (Under $75 possibly?)
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Every day carry small (2-4 inches).
____Every day carry medium (4-7 inches).
____Holster carry.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
I already own four rechargeable CR123As, and I used them in a $4 cheapo "3 watt" LED, which was actually very bright with a full charge. I guess what I'm getting at is, I'm unsure of the quality of the batteries, but they test around 3.7v if I remember correctly, when just off the charger. That was awhile ago, my memory might be off, though. It would save me some money to be able to use these. I wasn't able to use them in my SureFire G2X Pro, as I was afraid to overdrive the LED, which I read was only rated for 6v.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want ridiculous amounts of lumens (800+ lumens).
I could accept less than 800 lumens if I had to sacrifice it for price, runtime, etc.
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I want maximum throw possible)
Basically, I want a tight beam for far throw (spotlighting things at hundreds of yards away), but I will use the light for all ranges in EDC and weapon use.
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
I want the lumen output to remain high for as long as possible, and then the battery die, as opposed to a steady decrease in lumens over a longer runtime, if that makes any sense!
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
____I don’t know.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a strobe mode. (Blinks to show location.)
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____Recoil Proof
____Water Proof (This is flexible, but I at least want it to work in rain.)
I have done so much reading and searching on the forum that I am a little fatigued and overcome, so I'm hoping to ask the experts, as it were, personally. So, please post your recommendations!
Thanks for reading, and I'm open to opinions, comments, or questions.
3) Format:
____Holster carry.
6) Manufacturer:
____I don't care.
____I don’t know.
____Recoil Proof
