I bought two Inova Microlights long ago when target had the green ones on clearance and got them for $3 each. they have 3 modes generally high/low/strobe. I never used it a lot because of the green LED but they came with 2 2016 lithium cells so I decided to try and mod one with a white LED.
You can pop out the entire circuit board by prying the black plastic LED holder bar with a thin screwdriver or knife and the hole thing falls out. I figured I would have to unsolder the LED and solder a white one in. After removing the solder from the back of the circuit board and trying to wiggle the green LED it came out. :faint: but the LED had broken off with really short leads? no?
I soldered the two leads back to the circuit board after I realized that there is a socket for the green LED and you can just cut another LED and swap it into it easily. So this light is definately kewl as you can change LEDs at a whim in a minute without soldering.
