I just got the surefire KX4D upgrade for my surefire 6Z, but when I put it on, it does not work properly. It appears the spring that connects to the bulb and makes contact with the batteries is shorter than the original, which explains why the light flashes on and off when it is shaken gently. Also, the tail cap does not work properly with the new KX4D.
Has anyone else had this problem, and if so, how was the problem solved? Obviously I cannot use a light that is giving away my position, and does not come on when I push the tail cap.
