Surefire E2L upgrade
Jharpphoto
I want to upgrade my ancient Surefire E2L w/ KL1 head to something more powerful/current. What options do I have that won't be more expensive than buying a new jet beam PC20 or equivalent? I'm interested in greater brightness 200 lumens or so, good throw beam characteristics and possibly a user interface that allows a low output option as well. If this isn't possible which nitecore or jetbeam model should I consider. I'm open to all suggestions. Thanks in advance for all your knowledge.
I would suggest you look at the Surefire Fury, at 500 lumens, it is much more powerful than the current e2L, and cheaper than getting any replacement led heads for the e2l you have..
Even if I already have as well E2DL and P2X I recently ordered the KX2C head. It's expensive but I really like these Surefires and also want a head without pocket eating teeth. I hope for getting some tube for 2x18650s to use with the 200lm heads(if they tolerate the higher voltage).
