SixStars
- Joined
- Apr 20, 2019
- Messages
- 39
I’m considering adding a tailcap shroud to a Surefire EB1 Backup. I tried removing the aluminum retainer using a pair of quality USA made retaining ring pliers and even though I had a good grip in the two small slots, they slipped out and gouged the retainer a bit. I’m assuming that Surefire used thread locker of some kind.
My EB1 is a 300 lumen version, approximately 2016 vintage (based off of the battery that was installed) I just purchased it new in the box from a Surefire dealer. I mention this because I did find some reference on CPF from 2006 to older E series tailcap retainers. Another member had spoken with Surefire and they told them that they use Echobond and that it was more of a glue than a thread locker. Did Surefire use the same Echobond in 2016?
Has anyone successfully removed the tailcap retainer from an EB1 or E1B? If so did you heat the tailcap? If so how? Did you use retaining ring pliers or a tool similar to the one that Lumens Factory makes?
I’ve seen multiple discussions about E series tailcaps with shrouds that were added by Oveready but I can’t seem to find any that have been added to any EB1. Thank you.
