Surefire G2 beam cover
assaftolko
Hello, I'd like to purchase a beam cover for my G2, which has 1.25'' besel diameter and I havn't been able to find a cover for this diameter. Can someone help me with this?
I believe what you are looking for is a Surefire FM37 beam protective cover. Surefire has discontinued production of it but you can find it in stock if you look around. Take a look here. http://www.lapolicegear.com/sufmbe5.html
This works great on the G2 metal bezels. If you have a G2 plastic bezel I would caution you to be very careful when installing it. The earlier plastic G2 bezels are a little larger in diameter than the 1.25" making for a VERY tight fit. I had a protective cover clamp break off from too much pressure due to the larger plastic diameter bezel. Surefire did NOT cover it under warranty in my case.
thanks man! Also I'd like to get a remote switch for my G2, can you recommend me which one to buy?
