<font size="2" face="Verdana, Arial">The only problem with that is if you use a lock out tail cap. In that case you must use 2 hands to twist on, back off until light goes out, press button for 2-3 seconds, then twist off to lock out.Originally posted by MicroE:
I'm with Bart & Size 15.
The tailswitch makes all the difference in the world. Most of the time when I use a flashlight I use it for 2 or 3 seconds. The SF tailswitch is VERY convenient for this. The Arc is a two-hand-twist-all-the-time. Sorry, Peter.---Marc
<font size="2" face="Verdana, Arial">The only problem with that is if you use a lock out tail cap. In that case you must use 2 hands to twist on, back off until light goes out, press button for 2-3 seconds, then twist off to lock out.Originally posted by Sean:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by MicroE:
