desert.snake
My friend bought an M6LT and modified the diode, it’s easy - you need to heat it with a building hair dryer and use a vise + wrench
He put CREE XHP 50.2 3000K from kaidomain
then this driver was installed, there is no protection against overdischarge, the main thing is that it gives a very constant level of light right up to the depletion of batteries, like Elzetta driver + it fits perfectly in place of the native driver:
https://www.ebay.com/itm/LED-driver-LDR29-BUT-POWER-2-4A-Multi-Mode-2-4A-6-5V-27V-XHP70-XML/113691430331
When ordering, you could choose the levels, we chose 2.4 A and 0.4 A.
Next, I found a local store where there are a lot of AW battery. But here the capacity problem. 6*16340 600 mAh = 13 Wh. Then I made a drawing and ordered a pipe, now can put 3 * 26650 = 55.5 Wh. That's wonderful!
Now it’s like a pumped Maglight. But I have an idea to make a composite pipe so that can put 2/3/4 * 26650 depending on the task.
Has anyone else made such modifications?
https://youtu.be/pggH8Tm1Luk
