Robin24k
Quick update about the selector ring. Without going too much into the technical details, switching slowly from MIN to MED LOW may cause the UNR to turn off, and this is normal. Apparently, the U2 uses a similar design.
For those who are curious, here's a bit more detail. Hall switches are used for each output mode except OFF, and these switches are activated by a magnet on the selector ring. Since there's no Hall switch for OFF, there is a 200ms window to activate the next Hall switch once the magnet is moved away from MIN. If another Hall switch is not activated within this window, the light assumes that OFF is selected. Moving slowly from MIN to MED LOW can exceed this window, causing the light to turn off.
