Datasaurusrex
- Joined
- Jun 29, 2003
- Messages
- 665
A buddy has a shotgun with a surefire mounted in the foregrip. It looks like an old 6P permenatly mounted into the frip (you unscrew the bezel to change batteries, touch pad on grip to turn on light)
he hasn't used the light in a looong time because the batteries were dead... so I say lets see, it's surely just 2 CR123As.
Well it was some funky surefire battery, white shrinkwraped cells -- a DL223AZ 6Volt.
Under the shrinkwrapping were 2 cells that are labeled Durecell DL2/3A... and they are connected togather with a little soldered wire.
Is this just an old fashion way to power a 6volt light? Can I just give him some new CR123As for this light?
Any info would be appreciated.
Thanks
Thanks
