Surefire Weaponlight help
marshallwk
Im fairly new to lights but I figured id post here instead of the usual gun forums.. The other day i came across a SW02 tailcap and a 6p. I also ordered a malkoff m61W lamp for it to replace our crappy G3X lights on our weapons. Will the SW02 tailcap work? Or should i try to get a e series body with a z68 tailcap instead? I was thinking of getting a vtac L4 but since I already have these parts it would be cheaper to throw something together I think. I already have some g3s with surefire factory upgraded aluminum led heads but I read on here the bodys dont handle the heat as well as the 6p.
Right now I use a x300 but its way more flood than spot and is better suited for indoors.
The SW02 switch will work with/fit the 6P, now if it meets your needs as a weaponlight is dependent on how you plan to use it. I prefer/use unguarded forward clickys like the Z59 when a light is mounted on a weapon, while the SW02 and Z68 are guarded forward clickys.
