Re: Switching IC\'s
Hello there,
If you are willing to use two small pushbutton switches
(like those 0.2 inch square kinds) you can make one
button 'push on', the other 'push off', which would
make a VERY simple circuit using a power FET with a
low leakage cap on it's gate. One switch would charge
the cap and the other would discharge it.
You'd have to make sure it couldnt enter the linear
region unless it would handle the power.
Perhaps you could mention the voltage supply being
used also.
Even better...
A 'latch' circuit made by cross coupling two logic
inverters (probably CMOS) driving the gate of a power
FET.
Take care,
Al
