- Joined
- Sep 16, 2020
- Messages
- 1,342
I'm clearing out most of my collection to free up funds. After a trip out of the country with only a Peak El Capitan, I realized I can live with a much smaller and simpler set of lights.
Anyway, all prices are PayPal with F&F preferred (buyer may add 4% if they want to use G&S). Please do NOT include any notes or comments when sending payment. I will confirm shipping addresses via PMs here. Shipping within the US only, price will include insured shipping.
Timestamp photos and additional photos available upon request. Discounts given for multiple items purchased to be determined via PMs.
First public and unconditional claim to the item with prompt payment supersedes any other form of claiming the item. The listing may also be cross-posted to other forums.
1. Sunwayman V10R: $450 $425 $410 $400 $375
The crown jewel of my collection. This started (I believe) V10R+(?) and I swapped in a Nichia 219b 4000K. It comes with a 14500 adapter and body milled by BratGuy Industries; also a BratGuy titanium clip, Steve Ku (I think) E-switch with three green tritium vials. The vials still have good glow and the E-switch works as it should. I'm pretty sure I have the tin and will include it.
2. Modified HDS Clicky: $130
This was swapped to an XP-E with an aftermarket board. Clean white beam with good throw.
Stock light with a few small dings on the head and bezel as shown in the photos. The retaining ring in the head is loosened, but the pill and emitter are stock. I believe the light has been unlocked with the 250 clicks.
4. Cerakoted Novatac 17670: $125
Custom finish on a large body version of a classic light. This was a host only, but I was able to complete it with a complete stock pill with emitter. I believe this was also unlocked with the 250 clicks. It comes with the larger extended spring.
4a. Incomplete Novatac body and tail: $35 $25 $15
Only the stock 16340 body and tailcap with tail internals and raised button. Will need a spring and complete head assembly to be a functional light.
5. Foursevens Mini Mk3 Turbo: $55 $45 $35 $30
Stock and with normal wear from the clip. Magnet is in the tail.
6. Surefire Backup: $120 $110 $100
Anniversary edition, cosmetically and functionally in pristine condition.
7. FrazLabs QT Stainless Steel: $200 $180 $175
Pretty much brand new from Fraz. Never carried, just handled and tested a few minutes. No visible wear; will come with laser cut wood box and documents.
8. Arc LSH-P: $100 $90 $80 $75
CR123 body and 2xAA bodies included. Both Kroll switches work. Classic light with excellent build and clean white beam.
9. FW3A TiCu: $200
Now a much sought-after discontinued light. Emitters are warm-neutral tint, Opple reads it at 3100K, Ra 80. I believe the purple driver is the old (better?) one. Blue glow gasket is installed. Tail has retaining ring; comes with matching 18350 body and tube.
10. Elzetta Charlie C453: $260 $250 $240 $225
Standard bezel, HC head, high-low tailcap. Purchased straight from Elzetta a few years ago. Used for backyard critter spotting, no visible damage or major wear.
11. Elzetta AVS Head (prior gen): $75 $70 $65 $60
Purchased from ROG Tactical. Nice neutral tint found only in the prior generation AVS head.
12. Gladius Night-Ops: $60 $50 $40 $35
Deep scratch on the head, otherwise moderate wear on the body. Seems to work as it should with the tail cap switching modes.
13. Modlite PLHv2 21700 Body: $300 $275 $260 $250 $225
The head is a single-fuel PLHv2. All parts are like new, comes with a Modlite 21700 battery and Thrym Switchback clip.
14. Modified Nitecore EDC27: $90 $80 $75 $60
Emitters swapped to dual XML high CRI LEDs, 3000K tint. Awesome even beam. Will come with spare EDC27 (broken) as spare parts.
15. Niteye MSC20: $25 $20 $15 (can be a freebie with a higher value purchase)
Stock with XML emitter, tail rotary UI with stepped brightness. Body has some scratches but no dings, no clip.
16. Lumintop GT Mini Pro: $40 $35 $30 $25 (can be a freebie with a higher value purchase)
I was going to modify this one, but didn't have the time. Has a nice neutral beam, comes with short tube
17. Surefire Maximus: $150 $140 $135 $130 $120
Pretty much new, will come with original box. Worn 1-2 times for a few minutes at a time, charged only once.
Not pictured:
Twelve inch wire. Works as it should, good condition.
Jetbeam Jet-III Pro $50 $45 $35 $25
Decent condition with some surface wear. Ramping UI. Stock clip was broken, so I replaced it with a grey Thyrm LPC clip. Comes with diffuser filter.
Like new with original box. Clip and stud might need replacement as there is some side to side wobble.
