Hi all,
I am trying to decide on a tactical. After much research (my head is spinning!) I have narrowed it down to two lights, the Olight M20 Warrior Tactical R2 and the Jetbeam III M R2. I will be using rechargable 18650s.
The main problem I have with the jetbeam is the lack of a medium power setting. I like the programmable low power setting (allowing just right settings for night vision etc.). But only two settings corners me into low or full or I have to dive into a menu to get a medium level. I can see myself mostly using a medium or low setting with high as needed. Flat power regulation with 18650s (and 123s if used on occasion) is another plus. I also like the cylindical shape along it's full length without the bulbous type head of the M20. If I want to have a level somewhere between the low and high I have to play around with a menu to accomplish this and do the same again to go back to low. Compared to the M20 and the easy access it gives to 3 preset modes this seems more convoluted.
The M20 has the three power modes (plus the SOS and strobe), with different twists of the head giving quick and easy access to all modes. Since I envision spending most of my time in medium or low this seems to be less complex. This seems to fit my purpose very well. What is giving me pause is the lack of flat power regulation (from what I understand) with 18650s and lack of adjustment capability for the low mode (not allowing me to set exactly to my liking as the jetbeam allows).
The jetbeam would be the easy choice for me if it gave 3 power settings. Ajustable power levels for low and medium modes would have really rounded out it's feature set.
Anyway, how doable is using the menu structure to move between low and medium setting on a regular basis? Anyone with the jetbeam care to comment on this? Also does the better power regulation with the 18650s give it a tangible advantage over the M20?
Thanks in advance for any advice that will help me in my decision.
Of coarse, a "flashacholic" would buy both but that is not in the cards for me!
