Tailcap Question
Frank A.
Hi all. I have an old maglite that I haven't used in a while. I have been reading some mod threads and am contemplating my first mod. When I took the tailcap off, I noticed some corrosion on the spring. What can I use to clean off the corrosion? Thanks!
Regard,
Frank A.
What kind of mod are you considering? LED? Incan? You might not need the spring at all, or you might have to shorten/alter it. There is a good bit of resistance in that spring, many modders bypass it by soldering copper wire at each end. This , this and this are some examples of what others have done. Deoxit products are good for removing corrosion. Happy modding!
easy job for a 'bench grinder' with a wire wheel...or a wire wheel in a cordless drill.
