The HPR44 has a rated life of either 300 or 500 hours at 4.0 V and a lumen rating of about 54, If I recall correctly. In other words, it is relatively low efficiency at rated voltage.
It should draw about 4.6 V off of 4 fresh AA NiMH's and be 80+ lumens. I prefer the brightness of the somewhat easily available 3.85V 1.2A KPR 130 or 3.85V 1.32A KPR139 overdriven with 4AA's.
My Killer Tec40 will be a limited run time light with most or all of the lens removed for heat dissipation purposes. I am ordering a number of Carley 3.50 V 2.30 A Halogen T-1 1/2 bulbs potted into a ceramic PR base. At 3.5 volts the bulb is rated at 136 Lumens and 50 hour run time. At 3.9 V I should get 180 to 190 L
4AA NiMH's will voltage drop to 3.8 to 3.9 V at this amperage. At 3.9 V this bulb would be rated at about 180 Lumens and 16 hours life.
Currently I run a Carley 3.7 V 1.5 V Krypton Star in my most used PT40. This is 81 Lumen at rated voltage and brighter than the supposedly 110L 8X that I recently sold at the 4.2 or 4.3 V that is draws off of AA NiMHs. I run this combination up to ten minutes continuously without reflector damage.
