TEC and LuxeonV
hawkeye
Hillsboro, OR
Has anyone contemplated putting a Thermoelectric Cooler on the backside of the heatsink for a LuxV? Wouldn't the 5-7W difference create a DC voltage on the output of the TEC? Could this potential also be used to bias an LMO current- regulator circuit?
...Is caffeine really a suitable substitute for sleep?
Using a TEC as a generator isn't a good idea since the efficiency is so low - TECs are usually 30-35% efficient at best. A TEC does produce voltage when its sides are at different temps, but the impedance is so high that you won't get any appreciable current.
oO, who used to run TEC/water cooling on his computer...
To get any usable power from a TEC, you need a high temperature differential between the hot and cold side.
The purpose of a heat sink is to keep the heat generating device as close to ambient temperature as possible. Thus, the purpose of attaching a luxeon to a heat sink is to keep it as cool as possible.
These two goals are in conflict with each other.
Thus, attaching a TEC to a Luxeon V in hopes of generating power is simply asking to cause premature heat failure of the LED while generating a miniscule amount of power.
