Techlite Dude
- Joined
- Mar 28, 2010
- Messages
- 2
I was able to put a McClicky switch into one of my new Techlites for a fun modification. It was easy. All you need is a razor, a dremel tool (You can replace the dremel with a cylindical file and a drill), pliers, and something to unscrew the clear plastic switch retainer that is screwed into the battery cap. For this I used a snap ring remover but some small screwdrivers would work too.
The McClicky switch has 2 methods for powering on. Push it lightly and it comes on and off for a quick on-off or push it further to click it on until you click it off again. That is simple and I like it much more than the factory switch because I can turn it on and off quickly without looking at the beam. With the stock switch, I feel like I have to look at it as I toggle through the modes to make sure its off. This isn't cool if I'm trying to work on a car or something. The McClicky is a little too sensitive for my taste with the momentary on. However, it is much less of a hassle than what I go through with the factory switch. The McClicky's spring is pretty stiff compared to the factory one but it works OK. It makes it more difficult to screw the cap on.
-The McClicky is small and fits into the battery cap without using the McClicky's threading. It gets sandwiched by the clear switch retainer.
-There is a black retainer for the rubber button whose hole needs to be slightly bigger in order for a snug fit of the McClicky.
-The rubber button has a long post on the inside that needs to be cut short with the razor. Care needs to be taken here so its not too long or too short.
-The spring is removed from the clear switch retainer and a hole is drilled to fit the other in of the McClicky snugly. Bend the spring to the shape shown or something similar so that it touches the sidewall.
You can barely make out the spring through the clear retainer. I looks like the shape I drew and needs to wrap around the shaft of the McClicky so that it is sandwiched between the contact point and the retainer. The straight part of the spring needs to touch the side wall of the battery cap to complete the circuit.
After the mcclicky mod , my flashlight stayed on no matter what. This was because the rubber button post was too long and was pushing on the switch. After trial and error, I got the button post length correct. Use a sharp razor and take your time.
I got 2 mcclicky's for $16 shipped to my door from lighthound.com.
So I got 2 nice flashlights for about $16 each...and some fun modding action which is worth the extra money :party:
