Testing mag switch
Wildcat
Kingwood, Texas, USA
I was using my hot rodded 2C mag with 3X123 the other night. While I using it, it went out. I thought it was the bulb blew out. Put in a new bulb, still no worky.
How do I test the switch and all to see if it works or not?
Ok, I don't own a mag but here's how I would test a switch. First, make sure the batteries are good. Check your bulb to make sure the new one is not blown. Now, if you do have a meter, you can "probe" the contacts in the socket and try the switch to see if you get power.
If you can figure out how to remove the switch, you can check for continunity as well
