brightnorm
- Joined
- Oct 13, 2001
- Messages
- 9,027
[ QUOTE ]
PaulW said:
...As you probably already know, the more floodlike the beam, the more repeatable the measurement and the less sensitive it is to flashlight orientation. For flashlights with narrow beamwidth (long throw), I suspect orientation is the biggest problem. That is, the measurement varies wildly as the light is moved. I would guess that putting additional baffles in the box would reduce this effect. Ideally, it would be nice to be able to move the flashlight to any angle and still get the same measurement...
[/ QUOTE ]
Paul,
You can minimize that effect through a curved (ideally sperical) reflector and a positioning jig. I mentioned in my post that I was able to get virtually identical results between the Stinger and the Stinger HP, two totally disimilar beams of equal total output.
One idea for a poor mans integrating sphere:
Get a cheap plastic world globe. Poke holes for lens and meter, paint the outside white, check to make sure interior is white. If interior isn't white then spray paint and cut hole on opposite side to finish spraying.
Brightnorm
[/ QUOTE ]
Paul,
Brightnorm
