The new SHO can be installed in VME w/AA tube running Vapcell H10. Make a neat lil self defense light?
Yes, but you may want to consider using the E2 Super head which is identical in performance but smaller and much lighter.
What cell are you running in the (LF?) bodyYes, but you may want to consider using the E2 Super head which is identical in performance but smaller and much lighter.
I like the regular M91 for its wide, bright hotspot and beam.Ya it's like an M91 on roids. Right around the same output but more throw and as I said you can use two primary cells. And you get full output from 9 volts down to 3.8. Hope he makes more soon. I missed out of the first batch.
I am not interested in running any variant of M91, or M91T on 2x123. I was pointing out that M91T can run on1x18650, 2x18650 and 3x18650 as well as 2,3x4x123. Basically the same thing with better input options.Well kinda. You can run the 91 on 2X123 but it draws a ton over what's recommended. Also this new 61 has the same output from 9 volts all the way to 3.8. That's a new feature.
I slapped one in my cart before I really knew what I was looking for...They just dropped 60 of them M61 SHO, 59 left
46 nowThey just dropped 60 of them M61 SHO, 59 left
Thanks for the pic. Awaiting the arrival of mine.The M61 SHO is beastly 😎View attachment 47872
The hi/lo is just a retaining ring that holds the drop in inside the head. If you email Cathy at Malkoff, she might be able to make a custom order for you with all parts you want and send you the invoiceNewbie on Malkoff lights here! I want the HI - Low twist with new SHO
How do I get the M61 SHO with a High / Low switch MD2 flashlight?
Is that possible or do I have to buy the more expensive M61 High/Low Switch MD2 Flashlight and change the drop-in?
