TheKlone35
Dr.Jones
Germany
I have a TK35 and I like it, 2*18650 in a nice form factor, forward clicky and extra mode button, very good performance.
Since some weeks ago, cheap clones are available from the typical Chinese sites - I couldn't resist and got one.
Body quality isn't that bad, but as expected, performance was lacking (about 2/3 of TK35's), it had no memory, making the forward clicky more or less non-tactical (always low when switched on) and it had quite noticeable PWM. But I didn't intend to use it as is anyway.
I replaced the LED by a neutral white T6 3C, changed the battery setup to parallel, desoldered all components of the driver to make space for a NANJG105C 8*AMC7135 with a 9th AMC7135 piggybacked for 3.15A. (Here's an image: http://picz.to/image/gfs)
Result: Performance is only a few percent below the original TK35's, but with a nicer tint.
The standard driver of course doesn't support the mode button, so I reprogrammed the driver to use it; now I have a user interface that's even better than the TK's (matter of taste though):
Two main modes (switched by short taps of the mode button), plus ramping (long presses); strobe and beacon as hidden extended modes, and a battery indicator (number of blinks) at the begin of beacon mode.
I went on and programmed a firmware for the NANJG105C driver suited for lights with only an electronic switch (like the Zebras) with a similar mode structure (plus 'off' of course), plus a momentary ('tactical') mode.
You can switch it on in four ways: short click->previous mode, long press->ramp-up, double-click->high, triple-click->strobe (or whatever else I configure). Now I'm waiting for the UF-T50 I ordered to use this in. Can report then if someone's interested.
Good job Dr.Jones! Thanks for sharing this interesting mod. BTW if you are the same Dr.Jones that posts on DX's forum, thanks for all the helpful advice and suggestions.
