Rothrandir
Circuit Works CW2400 is a great conductive epoxy
<font size="2" face="Verdana, Arial">Are you saying that there are more than one PN junction in the luxeon? I guess I've always assumed that the luxeon was just a super led, and therefore just a larger PN junction. Does anyone have a schematic of the insides of a luxeon?Originally posted by Doug S:
I can think of two more plausible possibilities. It can be connected to the die via a PN junction to either of the power leads.
It would be hard for anyone to recommend a conductive epoxy without knowing what bulk conductivity you need for your intended application.
<font size="2" face="Verdana, Arial">I'm saying that it is a plausible possibility. In fabricating semiconductors, for process reasons the device sometimes will have a junction that is not required for the device proper but exists as a consequence of the fabrication sequence.Originally posted by Minjin:
As for needing to know what conductivity I require, I'm just looking for some general recommendations. I'm not building rocket ships here, just wondering what solder alternatives are available that don't cost an arm and a leg.
Mark
<font size="2" face="Verdana, Arial">Neat! It sounds like conductive epoxies have come a long way from the earlier versions.Originally posted by lambda:
Doug S,
Circuit Works CW2400 works just like solder; very conductive, with no measureable resistance. Hard to believe, but I've run amps thru small junctions with no measureable voltage drop.
<font size="2" face="Verdana, Arial">Actually Marc, I think quite a few use it. I know that I have. I seem to remember reading a review on one of those overclocker sites where they actually tested the thermal performance and found it to be quite respectable. For any thermal coupling compound, the thermal resistance is directly proportional to the thickness of the joint. The thinner the joint the better. JB Weld is a bit viscous. The trick to getting a thin joint is to heat the two pieces to be joined so that when the JB Weld is applied it heats up and thins so that it will squish out better when pressure is applied.Originally posted by MicroE:
I know that this goes against the wisdom in this thread but I use JB Weld. It's a steel-filled epoxy meant for mechanical repairs. It can be machined and sanded. It is also the strongest epoxy I have ever come across that is available commercially.
You can buy it at Ace Hardware stores in the US.---Marc
<font size="2" face="Verdana, Arial">Neither have I. That's why I've carefully mentioned multi-emitter arrangments. And to answer your question, they were wired up in series (for up to 3 emitters) and in a series-parallel arrangement (for up to 6 emitters).Originally posted by Slick:
Hotfoot - I'm curious if your tri-emitter mods were wired in series or paralell?
I've never had any problems mounting a SINGLE white emitter directly to the ground plane..
<font size="2" face="Verdana, Arial">Ouch!Originally posted by Slick:
At least the emitter was still useable - just had to route positive power through the die slug.[/QB]
<font size="2" face="Verdana, Arial">Thanks Hotfoot, I'm thinking that single and MAYBE parallel would be OK on the same ground plane.Originally posted by hotfoot:
<font size="2" face="Verdana, Arial">Bob, you have piqued my curiosity here. I interpret what you are saying to imply that in the case of the 5W cyan, the slug is common to one of the two power input leads. If correct, which one? Has someone here specifically checked a 1W cyan? I ask because somewhere I got the impression that in the case of the 1W cyan the slug is not a direct connection to either power lead. I am wondering if I got the wrong impression or if the 1W and 5W actually do differ in this regard.Originally posted by PsycoBob[Q2]:
My 5w Cyan has a a lower voltage drop from the slug to the other electrode, than from one electrode to the other. Not much, .3v at max, but... Enough to make me wonder if those little gold whiskers need to be upgraded to handle the 1.2A I put thru the LS.
<font size="2" face="Verdana, Arial">Bob, you have piqued my curiosity here. I interpret what you are saying to imply that in the case of the 5W cyan, the slug is common to one of the two power input leads. If correct, which one? Has someone here specifically checked a 1W cyan? I ask because somewhere I got the impression that in the case of the 1W cyan the slug is not a direct connection to either power lead. I am wondering if I got the wrong impression or if the 1W and 5W actually do differ in this regard.</font><hr /></blockquote><font size="2" face="Verdana, Arial">DOUG - If the slug on a 5W Cyan were to be common to one of the leads, it would have to be negative, because I just built a mod using one of these emitters and the slug is sitting directly on the negative ground plane.Originally posted by Doug S:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by PsycoBob[Q2]:
<font size="2" face="Verdana, Arial">Gee, Bob, I didn't know that I was such an influential guyOriginally posted by PsycoBob[Q2]:
Doug, you convinced me to yank my 5w light apart to test this. I had to pull it completely out of the light to get a good reading. It is bonded to the negative side. When in the metal-bodied light the voltage into the LED goes up slightly, due to the ground-current (and the fact that it's wired with a 22AWG negative ground).
Interestingly, to safely get a reading, I put a small blue wire-nut over the LS. Removing it almost 10 seconds later, I almost burned myself on it. The plate the LED was mounted to was still cool, as was the area around the LS emmitter. That certainly helped remind me about the amount of light it puts out.
