highlandsun
OK, so commercial thermoelectric modules are designed to operate with a delta-T (cold side vs hot side) of 200C. I found a design for a DC-DC converter that could extract ~130mW from a TE module at delta-T of only 20 degrees. What's the point? This is right around the range of heat that a Luxeon 1W emitter produces. (Bare emitter, 15C/W, Star 17C/W).
So if you put a TE module between the Star and its heat sink, you will very likely get that 20C minimum delta-T. With the module recovering 130mW during operation, you could reclaim 13% of the energy spent driving the LED. In other words, you could extend your runtime by 13%. With an overdriven Luxeon producing even more heat, you could recover more energy (the TE efficiency increases as delta-T increases).
The DC-DC converter design is here http://www.ece.uvic.ca/~jbornema/Journals/064a-97ia-jmd.pdf
Thermoelectric module specs are here
http://www.hi-z.com/index.html
