Thread forming taps.
*Out There* (Irvine, CA)
Precisionworks you say you use mostly thread forming taps, while I understand most of what they offer and the premise behind how they work vs cutting taps, I'm curious what applications would make a forming tap a better option than a standard tap? Also what kind of force and alignment is required? Do you need some type of drill/mill press or can they be hand started and hand turned?
I realize the results are cleaner and chip free, but what normal work would require that?
They are great for blind holes, no chip buildup in the hole or the need to keep backing out the tap to clean the chips away. If the hole is slightly too large for the proper cutting tap drill size specs then a forming taps will help correct for that since they require a larger drill tap size. I'm sure there are others benefits too.
Well, in large production quantities, tapping a cross-hole through the wall of a tube, there's actually substantial cost savings from simply not having to clear tap chips from the inside of the tube. But the main benefits there were speed (2-3x the spindle speed of a cut tap) and tap life (rather longer, even at the higher speeds).
They're really good for blind holes -- particularly when there's a tight limit on the depth (to avoid breaking through, or maintain a minimum thickness for strength) and the threads must be more than 2 diameters or so deep (which makes spiral-flute taps more challenging to use).
Also, the threads they leave are stronger than cut threads, so there's some application where short threads are necessary, but not strong enough, such as thin-wall tubing or sheet-metal. You can get good threads down to 2 threads thickness, at least.
The material matters, of course; they work great in aluminum, soft steel (even really low-carbon steels like 1005 that can be unpleasantly gummy with cut taps), and can be ok in brass. You wouldn't want to try them on cast iron.
WRT forces, they usually need about twice the torque of a cut tap, IIRC. They can be used by hand, but the higher forces translate into higher risk of breaking the tap without an alignment jig of some sort. They'll pick up their own lateral alignment like a cut tap, but (also like a cut tap) they'll easily start angularly misaligned if you're not using a fixture of some sort, and they are likely to break if you go very deep with an angular misalignment.
Pretty much what's been said ... blind holes get a former whenever possible. Holes requiring a very high surface finish are also formed, because most (but not all) cutting taps leave a somewhat ragged thread profile. Also, if a print calls out a class of thread fit, the former makes it easier (for me) to stay within the limited fit range - thread plug gages are used to verify that the hole is within tolerance.
I don't believe they can be hand started, as there's virtually zero thread lead. Mine are most often used in the lathe, with the part held in the chuck, the back of the former resting on the live center point, and the tailstock pushed forward (by hand) until a few threads are formed. Turn off the motor & use a tap wrench to finish if you want to be safe. Or let the machine pull the tap in close to hole bottom (in slowest back gear). If you put the former shank in a tailstock mounted Jacobs drill chuck, the shank will spin in the chuck when it bottoms out, as long as the chuck is not killer tight.
If you really tighten the drill chuck, don't be surprised at the results:eek:
