Swedpat
It could also be the size of the hotspot and the relative spill.
When you shine the light indoors how large of an area on the wall is lit up?
For me, a floody light will easily light up evenly a circle that is 6 feet or more at 20 feet. A "thrower" might only do 3 or less.
A stock mini mag (14 lumens) will throw farther than a small 200 lumen LED light. The problem being that it lights up a tiny area with not much lux.
Thrower for me designates that it becomes difficult to use at close ranges because I have to work around the glaring hotspot no matter how dim the light is.
A very good explanation! And in the same way a very bright spill can be negative even if the hotspot is very bright: the spill can blind on the foreground and worsen the eyes ability to make use of the bright hotspot.
For a thrower a beefy hotspot usually is an advantage but it should not have a very bright or wide spill.
A 10000lm light with 100000cd throws the same as a 500lm light with 100000cd. But in some cases the 500lm light is to prefer. Not only because of the size, weight and required battery capacity, but also because the 10000lm light will illuminate so much more area(and make unneccesary attention) than you might need to see.
