uh1c
Received my Tiablo A1 from Tiablo in China today. Initial impressions by a newbie. SEE PIX BELOW.
Well packaged for shipment.
Comes in small logoed box with instructions and 2 extra o-rings.
Empty 3/4 inch hole in foam-I have no idea what if anything was to go into it.
AAA, One output level, twisty. OP reflector.
Battery + terminal is to be installed toward head.
Threads slightly rough but not grinding. Seems lightly lubed with small amount of a thin oil.
Clip is easily (with care) removable and reversible.
2 small holes in base lip for a tiny keyring. Center post on base (like a Hyrashok) does not seem to serve any function but I'm no engineer.
Light weight, slightly longer & fatter than L0D-CE. (Barely worth mentioning)
Tail stands.
GITD ring (gasket?) around inside of lens.
Good anodizing, I spotted no flaws.
Eyeball meter: Brighter than L0D-CE on turbo. Brighter hotspot, less spill. I have to wait until dark to check it better.
Body appears to be same thickness as L0D-CE.
No odor from flashlight.
I cannot take acceptable pictures for posting to save my life despite my Canon A700.
Runtime: on fresh generic alkaline AAA: gradually dimming output to about 2-5 lumens: 3hrs
Water/Dunk test: 3 minutes in 5 gallons of tap water while turned on: No leaks. Works fine.
I like it!
Tail stands.
I like it!
