Re: Tigerlight doesn\'t seem as bright
[ QUOTE ]
js said:
[ QUOTE ]
Gman said:
Hmmm...I see. Well, I wanted to eventually put the TL in the car. I used to have a Magcharger in there but took it out because it was always dead when I needed it most. I first had it connected to charge whenever the IGN was on and later connected it to charge only when the heater blower was on. Went through several nicad sticks with that light. Guess I need a lithium powered light since I don't use it that often but I wanted the TL for the pepper spray.
How's about modding the charger to reduce the current to a full time trickle charge level, say 20 ma or so? Is that better than a timed maintanence charge at the normal charging current? For example I could put in a switch to select between normal charge and trickle charge.
[/ QUOTE ]
Yes, this would be the way to do it. I even proposed such a setup in The TigerLight Upgrade Thread.
However, I will have to disagree somewhat with turbodog on this one. I don't think a weekly top-up would be that bad for the batteries, provided you DO use the light a couple to three times a month. If you're just going to let it sit, then I guess I will have to agree with turbodog.
But even a continuous 20mA trickle charge with no use isn't good for the batteries over the long run, I don't think. As you surmised, a lithium based light is the best choice for a throw-it-in-the-car-and-forget-it type standby light.
[/ QUOTE ]
Well, not to start a Tl vs MC war, but some might consider going to a MC. It uses nicd cells which do not self discharge as much. These cells also will take more abuse than a nimh cell.
