TINY MONSTER NO LONGER ROARING
peterharvey73
Which version do you have MDJAK? V1.10 1108, V1.11 1110, or V1.12 1112?
[This should actually be Post #7 before the hacking occurred].
I ordered my TM early on and have had none of the teething problems I've heard others here experience. Mine has worked with different batteries and has been very reliable. Well, that streak has come to an end. I have it a couple of months and last night it failed to light when I went on my nighttime hike. When I got home, it worked fine. I changed the batteries and went out again tonight. Once again, it came on, no problem, and then began flashing, one led only, and wouldn't work at all. I put it in a holster, pulled out my backup light, and continued on. About an hour later, as I'm back in my car, the TM comes to life in the holster. I immediately pull it out and shut it off.
I unscrew the end, rescrew it, and the battery level shows four plus 2, meaning fully charged. I turn the light on, it stays on for about a minute, and then it goes off.
Now I have to remember what website I bought it from. I bought so many lights in the past few months, I don't remember. Damn.
Mark
Sorry for your bad luck hopefully they will replace it for you free of charge.
yeah my TM worked for a couple weeks with no faults then it started flashing and then only 2 leds would turn on after that. but the place i bought it from replaced it, not that i even wanted it any more cos it made me dislike the light.
i cant believe these lights were sold or even let out of the factory without testing. to me now nitecore is in the same quality category as no name ebay led lights..
Had mine since January with nary a problem. I hope this isn't an issue that will bite me in the butt when i least expect it. I use mine 5-6 nights out of the week (40+ hour work week) and I hate for it to crap out on me while patrolling. Have a backup light just in case.
have you a voltmeter and checked what all the batteries volts are, at the time of error condition ?
what are the actual volts on each battery ?
Thanks for replies. I don't have voltmeter but I tried different batteries all fully charged. Batteries that have no problem powering my other lights.
If you unscrew the head from the battery carrier, the version number is inside the head, like this photo courtesy of Selfbuilt: 1.10, 1.11, or 1.12?
