Background:
I've found the Astrolux S41S (with an extender for the 18650 battery and a tritium vial on lanyard) to be a great travel light (with a few exceptions). Let me explain:
* It starts in moonlight mode (I think about 0.5-1 lumen). Great for not blinding myself in the middle of the night in a hotel room I can't find my way around.
* It has a great flood beam for searching for things dropped under beds, airplane seats, etc.
* The various modes always seem to let me find a good level of output for what I need
* It has enough power to check out what's going on in the yard
* It has a very sturdy feel
* It takes an 18650 (and I carry a USB-rechargeable 18650 in it, so I can always charge it)
* It can stand on the tail cap (although not well)
* It can also take a single 18350 (or even a CR123A in a pinch)
* It has a good grip (tough knurling, maybe a tad too aggressive)
* It goes in the pocket fairly well (could be better--again, that knurling is somewhat aggressive). It doesn't have any sharp areas that would poke (like a defense bezel). I want a smooth light with enough grip that I won't drop it easily.
It has a few cons which I'm hoping to be able to correct with my next light:
* It is heavy (made from stainless steel). I like the sturdyness, but I'd prefer titanium for weight.
* I'm worried that the 1600 lumen mode creates too much heat. I forget where, but I read a post about someone burning one out. I want my light to not let me break it as long as I'm using it with the modes it provides.
* It can roll off the counter (perfectly round). I'd prefer a bezel or clip or something that would prevent this. My old surefire 6P LED Defender did a good job of this with the hex bezel, but I just need a slight notch or something.
* It has no tritium inserts so I need to put the tritium on a lanyard
* It's wider than it needs to be (thick stainless)
* The tailcap looks weird in semi-clear rubber
* There are a few too many modes and special clicks needed
I've filled out the questionnaire below.
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $300. (hopefully? I know titanium can add a lot)
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
Single 18650 (if it could adjust to fit other lithium cells (e.g., with a smaller extender tube), that would be cool)
5) Emitter/Light source:
LED - bonus would be a warmer beam and/or higher CRI numbers
6) Manufacturer:
Any of the following:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I would like a light from a specialty manufacturer (Possibly limited run/Custom).
I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
18650. I'd prefer if it could also take two CR123As
Must have: option to swap battery
Would prefer: option to charge via USB (preferably USB-C, but I'll take USB micro) (would not give up waterproofness for this)
This is going to be a "travel" light
I like the moonlight (~1 lumen?) default mode of the Astrolux S41S.
I'd like several modes going up to 1000 lumens.
Again, I like the Astrolux S41S here: pretty wide, but at 1000 lumens, you can light up a yard. No "hot center", but it could be a tad narrower than the S41S.
Both of these:
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
As long as the light is competitively efficient, I'll be happy with whatever my 18650 can deliver.
Very Important (Camping, Backpacking, Car Glove-box).
I've heard concerns about the Astrolux S41S at the max output. I would want to be confident that I could run this thing at max output and it wouldn't overheat and break. If that means cutting down the output after a few minutes of run time, that's a sacrifice I'm willing to make. Just don't surprise me by breaking.
I want to have this light for a long time - maybe even pass it on some day.
I want a tail mounted switch (found on the majority of today's high end lights).
Probably (what I'm most used to): I want multiple light levels. (Some lights have 5-16 light levels.)
I'd also consider: "I want a programmable light."
Less important, but potentially desirable:
I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
I want SOS mode. (blinks in ...---... emergency pattern)
I want a beacon mode. (Regular flashes at full power to show location.)
14)Material/Finish/Coating
Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Water resistance
I'd prefer IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
I would like flexibility here, but practically speaking, it will probably be in the house 95% of the time. The other case would be in an automobile potentially.
Needs:
* As compact as an 18650 can be (no extra length or width used up without reason)
* Tritium placed so it would be hard to not be able to see at least one tritium
* Replaceable tritium (worried about gluing tritium in and not being able to replace after they half life away)
* First click is moonlight mode
* Not perfectly round (so it won't roll off a counter)
* Stable on its tail cap pointed at the ceiling (like a lanturn) the Astrolux S41S tail cap design makes it somewhat unstable when pointed at the ceiling
Wants:
* Charge indicator (or low bat warning giving maybe 30% left?)
* Low red light would be great, but not needed
* Magnetic charge port would be cool
3) Format:
4) Size:
6) Manufacturer:
Both of these:
Needs:
Wants:
