[FONT="]
PREPARING THE PISTON FOR USE:
[/FONT]
[FONT="] The first thing you want to do is lubricate the o-ring. Use chapstick, grease, lard, etc. This will ensure there is an airtight seal and help create compression. [/FONT]
[FONT="]
Insert the piston inside the tube and push down on it lightly several times, this helps lubricate the inside of the tube. [/FONT]
[FONT="]
Remove a small piece of char cloth from a char cloth square and shove inside the bowl shaped end. If you’re using the rod with the smaller hole in the end, cut a rectangular piece and fold in half.[/FONT]
[FONT="] Then roll and press using your finger tips. The end result should look like a piece of rope. [/FONT]
[FONT="]
[/FONT]
[FONT="] Insert this into the hole making sure the char cloth extends about 1/8 inch out of the hole, any longer or shorter may make it harder for you to ignite the char cloth. You are now ready to use the piston.
[/FONT]
[FONT="]
USING THE PISTON:
[/FONT]
[FONT="]
The easiest way to get the piston to light is to be in a kneeled position, similar to how you would be getting ready to light a camp fire.
Place the tube over the rod, so that the o-ring is barely resting on the lip of the tube. [/FONT]
[FONT="]It is important that you begin compression with as much air trapped inside the tube as possible. If you start compression 1/2" way down the tube or even 1/4" down the tube, it will be very hard or impossible to get ignition.[/FONT]
[FONT="]
Using the palm of your hand, push down on the piston. Use your body weight as leverage to come down on the piston hard. You must force the piston down
AS HARD, AS FAST, AND AS FAR DOWN AS POSSIBLE. If you remember anything from these instructions, remember that. You are trying to create compression in the piston so that the char cloth ignites. Following the bold text will maximize your chances of ignition. [/FONT]
[FONT="]Immediately after compressing the piston, remove the rod from the tube and check for an amber. If no amber is present, repeat the steps, making sure you are following everything correctly. If after the 3rd attempt you fail to get an amber, Try adding more lubrication to the rod and check the o-ring for damage. You can also try using a new piece of char cloth. [/FONT]
[FONT="]
STARTING A CAMP FIRE:
If you’re trying to actually start a fire with the piston, get yourself set up with your kindling first. I like to make a teepee shape with small skinny dry twigs, and set a wad of tinder (dry grass, cotton, or anything that will catch a flame easily) in the middle of the teepee. Once that is set up, I get another wad of dry grass or any other available tinder and put a square of char cloth on top. I lay the wad on the ground and push down on the char cloth in the center flattening the wad a bit.
Now, use the piston to make an amber, transfer the amber to the larger piece of char cloth and then fold the wad in half and begin to blow. It helps if you cup your hands and hold the wad of tinder like a ball in your hands. You will begin to see smoke after a few seconds. You will have to blow air on the wad for a good minute before it ignites. You will begin to see more smoke and start to feel the wad get hotter, once it gets hot enough the whole wad will ignite, at which point you can transfer that wad to the other wad under the Teepee which will get your small twigs on fire.
I also encourage you all to make your own char cloth. It is a useful skill to learn and its easy to make, even at camp. Here are 2 videos from youtube that are very insightful:
http://www.youtube.com/watch?v=H_89Fm3slyE
http://www.youtube.com/watch?v=JCb1rYrk92s
I think the nicest thing about a fire piston, is it brings you back to basics making you more efficient at lighting a fire.
I remember before I got into fire pistons I would go camping and I could easily go through an entire book of matches trying to light a fire. I could douse the wood with gasoline or kerosene, and still take a while to get the fire going.
The use of the piston forces you to set everything right the first time, if you fail to set everything right, it won't light.
So you can think of this as training or practice for that one day you may need to start a fire with one match or with only a couple of matches, or no matches at all.
I can now proudly say I can start a camp fire using only one match or one amber from a fire piston. [/FONT]
