TK10 / 11 question
geoffg
I have a p3d and to be honest i am not too impressed with the possibility of the torch accidentaly turning on when i have forgot to slacken the head (leaving it on turbo) before putting it in the holster. Am I right in thinking that this,if it goes unnoticed will burn out the P3D?
Anyway, question is, will this burn out a tk10 / 11 or are these designed to run on full power indefinately?
TIA
Geoff
It would almost defanatly damage the bulb lf left on in the holster however you can use them and just drain a set of batteries with the tk10/11 on turbo as long as it isn't an overly hot enviroment or the light hasn't been left all day on the window sill however the most i have gone with my TK11 is 35minutes and it was fine, just a bit warm around the head. If you are woried about the TK10/11 switching on in the holster then simply loosen the tailcap a half turn so that when you click it nothing happens and it is esencially locked.
I've drained my TK11 in turbo with no ventilation; actually lying on my bed. When I picked it up the whole body was a couple of notches above warm, nowhere was it "hot" though. The thermal mass of the T series means that they're happy enough running on max, even without cooling.
I use my P3D off & on as a work light. I once accidentally turned it on, in its holster; on turbo mode. Didn't notice it for at least 45 minutes. The body was hot as Hell! Couldn't even hold onto it. I somehow managed to turn the light off.
That was quite a while ago. The emitter didn't burn itself out. Still as bright as the day I got it. But no doubt I shortened the lifespan of the poor little emitter.
