I say go for it!!! I got mine and even if it's bigger then then other or this or that, I think it's a great light for the fact it used batteries you can find just about anywhere in the world. It is also a tough light and great thrower.
Is Aurora a good company as far as design, build quality, and customer service? I can't even find Aurora website. The only site with Aurora name is Aurora Tactical and they only carry 1 flashlight while having super high end optic products in the 20s of thousands.
Please also give me coupon code for DealExtreme.
How does the TK40 compare to the Aurora AK-P7-3 SSC P7-C 900-Lumen 2-Mode LED Flashligh? I really like the 900 lumen factor but not sure why neither Aurora or DealExtreme lists the run time for this light under various mode. The only listed run time is on turbo and it's about 1.5 hrs.
I think this may be the light for me. Is Aurora a good company? Has anyone deal with it or DealExtreme? Anyone has a coupon code I can borrow.
Thanks.
I have this light - it is nowhere close to 900 lumens. It probably puts out 350 lumens if it is lucky - lucky as in if it works when you get it from DX.
Mine didn't, it was non-functional when it arrived. I had to do some repairs to get it to work somewhat reliably. You will find this with most of the cheap DX lights - the high lumens that are claimed are theoretical amounts that could be produced under ideal conditions in a laboratory setting - not out the front lumens in the real world.
The light gets quite hot after a minute or two and the output drops further the hotter it gets.
Don't get me wrong, it's a bright flashlight - but you get what you pay for, and it is not anywhere near the league of some of the better lights available.
If you want an inexpensive, good quality MC-E or P7, get an MG PLI - only about 20 dollars more than the DX lights and vastly better IMO
If the halogen spotlight you're thinking about is a 5 million candle power, 6V 55W spotlight or something similar to that, then taking it out into the bush its heavy and not the easiest thing to carry.I was considering the TK40 to replace a halogen spotlight but someone mentioned its more of a floodlight than a spotlight. I like the fact that it takes AA batteries but I would have liked a settng in between high at 277 lumens and turbo at 630 lumens. Any Aussies here use this light for spotlighting in the bush at night?
Fenix Lumens of 630lm are out the front. If the fenix was only putting out '380lm', then your beamshots wouldn't look so alike.Overall light output - some say TK40 is brighter compared to M1X, but it just isn't true. I guess this opinion might be caused by different manuf. rating. TK40 says 630 lumens, M1X says 450. The difference is that TK40 rating is for the diode, whereas M1X is for the actual flashlight output (diode having 700lm). I'd guess TK40's actual output is somewhere around the usual 60%, 380lm.
In conclusion, both flashlights are great, but come on, M1X is the clear winner here. Considering TK40 is $10 more expensive...
Actually, your pics show that the M1X covers a lot less grass than the TK40. It is possible that if the TK40 was aimed higher, in this case that would be as high as the M1X, we'd see a much brighter view.
There are 500,000 candle power halogen lights. I think mines a dorcy, it has a cigarette lighter plug ,and its really cheap but beam is really ugly compared to the TK40. In terms of illumination, the TK40 is much much better. It has a smooth spot and great spill and shines a long long way. It nothing like a flood light but you can use it as one because the spill lights up a bbq area really well from a height.
Only wish the tint was different. When the beam hits close up silvery foilage, its a little too bright and it hurts the night vision.
Yes thats exactly the sort of spotlight I have. Its a Michelin one actually same as the tyre company but with a built in battery it is quite heavy and only lasts for 15mins on a charge. I wasnt it actually wanting it for shooting but bushwalks and camping trips to spotlight all the nocturnal animals that come out in the trees etc. The Michelin you cant really take bushwanking its just too large.
